Engine idols fast
204,000 MILES • 2.2L • 2WD • MANUAL
CAJUNGUY1965
  • 39 POSTS
My 1995 Chevy s10, 2.2 ltr engine idols extremely fast. While driving,it almost dies out. I lose speed and power. I have changed fuel pump,fuel filter,one fuel injector(because it cracked while checking connections). I can't see any vaccumm leaks. It's a 5 speed manual transmission. Truck was running decent until I changed fuel filter. Then fuel pump wasn't pumping proper pressure to keep truck running. I am puzzled. I even changed throttle position sensor. It still does the same thing. Anyone have any idea what can cause this? I need to repair as soon as possible.
Jan 13, 2016 at 3:15 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner. then check for vacuum leaks as well as holes in duct work
Jan 13, 2016 at 4:03 AM
CAJUNGUY1965
  • 39 POSTS
I have already done that. Same result
Jan 13, 2016 at 4:05 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge then if a 4 cyl 41-47 psi auto parts rent it. if you replaced fuel filter make sure it is on correctly.
Jan 13, 2016 at 4:09 AM
CAJUNGUY1965
  • 39 POSTS
Fuel pump is new. So is fuel filter. Had old pump checked. It wasn't putting out proper pressure so I changed it. I don't have a scan tool. I been trying to figure what is causing this
Jan 13, 2016 at 4:12 AM
HMAC300
  • 48,601 POSTS
auto parts can scan most engine problems. however normally it's a vacuum line off/cracked etc or hole in duct work leading to engine or grommets on engine.
Jan 13, 2016 at 5:07 AM
CAJUNGUY1965
  • 39 POSTS
Parts places can not scan 1995. It is a year too old. Mine has a bd1 system. Parts places can not scan bd1 system. Only bd2 system in general motors. I will continue to look for vaccumm leaks. But haven't found anything yet
Jan 13, 2016 at 5:13 AM
also, check the idle air control motor on the throttle body. it controls idle speeds
Jan 13, 2016 at 6:50 AM
HMAC300
  • 48,601 POSTS
if it's obd 1 use a paper clip on
A & B on aldl and turn key on it will flash light count flashes get back to us if it just does 12 then that means the system is working ok
Jan 13, 2016 at 7:17 AM
CAJUNGUY1965
  • 39 POSTS
I have found the vaccumm leak. It's on the main air intake. Need to change the gasket. Thanks a lot for your help and expertise.
Jan 14, 2016 at 2:46 AM
