1995 Chevy S-10 quit while driving - won't start again
RANDYINYAKIMA
  • 1995 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 134,000 MILES
Quit running while driving down a residential street.
Has been sitting for 18 months.
I suspect the timing chain went out.
How do I check to diagnose?
Monday, October 25th, 2010 AT 7:21 PM
1st check the fuel pressure if its within specs-could be the fuel pump went byebye or do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Monday, October 25th, 2010 AT 7:26 PM
