Engine idels down on it's onw
GOLDCHEVY
  • 1996 NISSAN PATHFINDER
  • 100 MILES
My1996 Nissan pathfinder runs great but when I go to a stop it idels down so far it almost dies then it idels up where it should be and every thing is o.K. No check engine light come on. Or if I cruse around town or on freeway it will kick and buck a little and it don't miss fire eather while it is doing all of this. I replaced the fuel filter, cap and rotor and it still does it.
Tuesday, August 6th, 2013 AT 11:08 AM
  • 109,867 POSTS
Have you checked for vacuum leaks and the idle air control valve (IAC)? The IAC is responsible for maintaining the engine idle.
Tuesday, August 6th, 2013 AT 7:57 PM
GOLDCHEVY
Thank you, I will check that.
Wednesday, August 7th, 2013 AT 12:48 PM
  • 109,867 POSTS
Let me know what you find.
Wednesday, August 7th, 2013 AT 3:28 PM
GOLDCHEVY
Well, I went to the dealer and there was a knock sensor fault, and a had the wrong plugs in the Nissan, I had the Bosh plugs and I has been four years ago I replaced them. So I got the ngk that they use. So they eaid to do the plugs first.
Thursday, August 8th, 2013 AT 4:38 PM
  • 109,867 POSTS
Has the problem been taken care of? Let me know.
Thursday, August 8th, 2013 AT 6:18 PM
