1998 Nissan Pathfinder Cylinder 6 Misfire
NAGY
i have a 1998 nissan pathfinder 6 cylinder 4wd. i changed the plugs,wires,dist cap and rotor but i't still not running right. when i hook the code scanner up it tells me 6 cylinder misfire. do you have any idea what it might be? it has 95000 miles on it.
May 16, 2007 at 12:19 PM
  • 75,988 POSTS
[quote:12c57a7ce7="nagy"]i have a 1998 nissan pathfinder 6 cylinder 4wd. i changed the plugs,wires,dist cap and rotor but i't still not running right. when i hook the code scanner up it tells me 6 cylinder misfire. do you have any idea what it might be? it has 95000 miles on it.[/quote:12c57a7ce7]
Dirty injector and burnt exhaust valve for that cylinder.
May 16, 2007 at 11:39 PM
KAMO
  • 47 POSTS
Also check for proper gap
May 18, 2007 at 8:43 AM
Suggested Repair
Check cylinder 6 for a dirty fuel injector and a burnt exhaust valve. Also verify that the spark plugs are gapped correctly.
Conversation Summary
The owner of a 1998 Nissan Pathfinder with a cylinder 6 misfire replaced the plugs, wires, distributor cap, and rotor, but the engine still ran poorly. An expert suggested a dirty injector or burnt exhaust valve on that cylinder, and another reply advised checking the plug gap.
