The engine fires a few times but will not start, where is the Crankshaft Position Sensor located?
170,000 MILES • 2.6L • 4 CYL • 2WD • MANUAL
SHOWTIME2
  • 5 POSTS
Ran codes using a jumper wire. Got a code 41. Crankshaft position sensor error. Can't locate the sensor on the engine.
Apr 24, 2024 at 8:27 AM
SHOWTIME2
  • 5 POSTS
What I need is the location of the crankshaft position sensor. 1992 Isuzu amigo 2.6 5 speed.
Apr 24, 2024 at 11:23 AM
  • 110,251 POSTS
This doesn't have a traditional crankshaft position sensor. On this vehicle, it is a pick up coil inside the distributor. See pic below.
As far as the problem, have you checked for diagnostic trouble codes? If not, here is a link that explains how to check:
https://www.2carpros.com/articles/mitsubishi-trouble-code-definitions-and-retrieval-procedure-for-odb1-system
If you haven't already, I recommend checking for codes.
Let me know what you find,
See pic below.
Apr 24, 2024 at 12:22 PM
SHOWTIME2
  • 5 POSTS
Thank you, Joe. It seems I found the right place for answers. Your info helps a ton. I did run diagnostic test. Got code 41. But I'm going to use the link you sent and see if I get anything more. Thanks a bunch. I'll update you on progress as it comes.
Apr 24, 2024 at 2:02 PM
  • 110,251 POSTS
You are very welcome. As far as the code is concerned, it is related to the sensor you mentioned.
If you look below, I attached the diagnostics specific to the code. Take a look through them and let me know if you are comfortable performing them.
Let me know what you find.
Apr 25, 2024 at 12:17 PM
SHOWTIME2
  • 5 POSTS
Don't understand.
Apr 28, 2024 at 8:07 AM
  • 110,251 POSTS
No problem. The diagnostics are to determine if the pick-up/crank sensor is working properly.
If you are uncomfortable performing the test, by any chance do you have access to a different distributor?
If not, try this. Disconnect the battery for approximately 30 minutes. When you reconnect it, the code should be cleared. At that point, crank the engine a few times and see if the code comes right back. If it does, I suspect the distributor may need replaced.
Apr 28, 2024 at 12:03 PM
