Engine failure
200,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
POMSKI123
Hi, I am just wanting to ask if anyone had any idea why my car is stalling while driving? it is happening all the time now after driving for twenty minutes.
Then will not start for fvie or so minutes.
Got it scanned and it said top end crank sensor replaced that same issue took it to a auto electrition they replaced wire from ECU to the sensor, but still we have this issue.
Aug 14, 2016 at 10:30 PM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge and clean throttle plate on both sides and IAC hole with choke cleaner.
Aug 14, 2016 at 11:54 PM
POMSKI123
Ok well I'm not very good with cars would u go to a machanic or auto electrician?
Aug 15, 2016 at 9:15 AM
HMAC300
  • 48,601 POSTS
mechanic they are both the same
Aug 15, 2016 at 9:28 AM
POMSKI123
Thanks mate I'll see how I go but I was thinking electrical as the engine just cuts out but radio stays on
Aug 15, 2016 at 12:33 PM
SATURNTECH9
  • 30,869 POSTS
Just to add to this one can get the exact code numbers not code descriptions your car has?It's sounds like a component gets hot stops working cools down and then works.
Aug 16, 2016 at 8:46 AM
