Engine dies out on start up
220,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
SHANEMJEFFERS
  • 7 POSTS
Hey folks. I have a 1998 Ford Expedition, upon turning the key the engine fires over but immediately dies out. I have replaced the IAC valve to no avail. I have tried spraying gasoline in the throttle body and sure enough it idles.. but heres the kicker.. when I have the IAC plugged in it immediately dies out, however when I unplug it it will idle for a few minutes (rough) before it dies out.. please help
Aug 12, 2014 at 11:34 AM
  • 110,248 POSTS
Have you checked fuel pump pressure? Also, has the check engine light come on?
Aug 12, 2014 at 3:10 PM
SHANEMJEFFERS
  • 7 POSTS
Fuel pressure was good, and yes the check engine light was on. I did finally get it figured out though, It was a vacuum line on the air intake causing the engine to stall.. it showed all the symptoms of the IAC sensor but was as simple as a broken line. Thank you for the response though!
Aug 12, 2014 at 3:38 PM
  • 110,248 POSTS
Glad you found it. On this engine, there are a couple behind the throttle body that have 90 degree bends in them. If there is a vacuum leak, usually it is one of them.
Aug 13, 2014 at 9:08 AM
