Engine shut off while driving, only clicks when starting
130,000 MILES • 3.0L • V6 • 2WD • MANUAL
JOWKA
So my kid was driving when this happened, the truck shut off and when going to start it again it just clicks. I originally thought alternator, but when I curbed the battery it was 12.4, charged up the rest of the way and went to turn over and still clicks. There's also leaking fluid which appears to be transmission fluid. When it got towed, the fluid shot on the underside of the hood as well, and while sitting it didn't leak but as soon as it was pushed it started leaking again. Any ideas of what this is? I'm almost guessing the motor seized up, but hoping there may be something else.
Oct 18, 2020 at 4:44 AM
I would agree that the engine sounds locked up. However, we need to confirm this by putting a wrench on the crank pulley bolt and turning the engine by hand. If it spins then it is not locked up and you most likely have a starter issue.
Here is a link to a guide that will help with a starter issue:
If you cannot spin the engine over, let us know and we can go from there because depending on what happened we may be able to break it loose but we are going to need to drain the oil and look for metal. Thanks
Oct 18, 2020 at 4:55 AM
JOWKA
Right after I posted this, I decided to try just that. I was moving the entire body trying to get it to turn and couldn't get it to budge. So now I'm really thinking it's seized up. What would your ideas be for freeing it up?
Oct 18, 2020 at 4:58 AM
That is not great. We need to assume that since it was running when this happened that it is a seized crankshaft. if that is the case, the only way to free it is to rebuild it as the bearing are metal to metal. So that means we need to try and confirm this. The way to do that is you need to drain the oil into a clean pan and let it sit for 20 minutes so the metal can settle to the bottom. Then run it through a coffee filter. Then look for metal in the bottom of the pan and in the coffee filter. You should see a very small amount of metal but I suspect it will look like glitter. If it does then you probably need to replace the engine.
If this were seized due to rust or sitting for a long time we could try some tricks to free it but when it happens while running, there is not much we can do. However, if we don't find metal then it may be vapor locked and there are some things we can try but lets check the oil first and foremost because if there is metal, all else is just a waste of time.
Oct 18, 2020 at 6:23 AM
