Friday, November 28th, 2008 AT 9:11 PM
Ok. So this is going to be long. And im desperate for help. So i'll do my best to explain: I have a 99 Ford Ranger XLT. 2.5 4cyl automatic that has almost 130,000 miles on it. I made the mistake of allowing my fuel tank to run too low for too long and it began getting sludge in the fuel line. I made a point to keep plenty of fuel in it, replaced the in-line filter and gave it the correct ratio of Sea Foam/Injector Cleaner Gum out, etc. This corrected the issue for a brief time. Then it started acting up. When I would try to start the truck, it would hit over but not enough to run the engine and it would stall. If I lightly placed my foot on the pedal *I know you shouldn't have to on a fuel injected vehicle* it would start up, obviously rev a bit high and then settle into a good idle. This carried on for a few months and then it got worse. It started to idle very rough, so I checked the spark plugs and wires. They desperately needed changed. I changed them and I noticed an instant difference. The truck started up, ran, idled wonderfully and had added horsepower. Two days after it began to repeat the process. Stalling and not wanting to idle. Does anyone have any flipping clue as to what's going on? As I said. Im at a loss and im completely desperate.
