1999 Ford Ranger engine dies when I brake
LEWMANJ
  • 1999 FORD RANGER
  • 4 CYL
  • MANUAL
  • 139,000 MILES
When I turn my truck on the idle seems low and it kind of chugs. When I brake abruptly it dies. But once it gets warmed up it runs fine. I think it may be problem with the choke/carburator but I am not sure. Any ideas?
Thanks a lot
Monday, July 13th, 2009 AT 10:27 AM
  • 109,885 POSTS
Your car doesn't have a choke. It is fuel injected and the fuel mixture is run by the computer. If this problem happens when you hit the brakes, check the brake booster to make sure there isn't a vacuum leak to it or the booster itself isn't leaking. You will need a vacuum gauge to check it. Many parts stores will rent them. If there is a leak, the booster will not hold a vacuum and will need replaced.
Monday, July 13th, 2009 AT 1:20 PM
