Engine cranking but not starting
112,000 MILES • 4 CYL • AUTOMATIC
DGOODY
Hi, So I just bought this car two days ago, and it recently just passed annual inspection. It has been running just fine, except for a screeching noise while starting, as if a belt was defective. Today, I tried starting it multiple times and it would turn over but not start. I had a mechanic friend come over and look at it, and he checked it all. It is getting spark in all the plugs, it is getting fuel with great pressure, and it is getting compression. He said it sounds like the timing is 'off' but the timing belt is just fine. Everything seems to check out but it just will not start. The engine light is on while running, so the seller and I checked with a OBD scanner and it says that bank one is reading rich. He recently just put some really nice fuel in so I do not know if that may be it. I am not mechanically inclined so I would not have any idea.
Mar 4, 2017 at 9:42 PM
  • 55,711 POSTS
Hey DGOODY,
I would start with a compression test to make sure the timing belt has not slipped out of time. Here is a guide that will help you get the problem fixed.
and
https://www.2carpros.com/diagrams/dodge/neon/2002
Please let us know what you find so it will help others.
Best, Ken
Mar 6, 2017 at 2:01 AM
