Code P2184
200,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
MUSTAFA ELSHARIF
Engine coolant temperature. How can i repair code p2184?
Dec 11, 2017 at 8:13 PM
  • 31,937 POSTS
This code can be set by one of the following problems, they will all have to be checked, if the heather is not as hot as it should be look at the thermostat first.
Low coolant level Faulty Engine Coolant Temperature Sensor Stuck or leaking thermostat Engine Coolant Temperature Sensor harness is open or shorted Engine Coolant Temperature Sensor circuit poor electrical connection
Dec 13, 2017 at 8:23 PM
