1998 Honda Civic engine codes
AN2NY0830
  • 1998 HONDA CIVIC
  • 4 CYL
  • FWD
  • 149,000 MILES
Theres a check engine on my car and I had it diagnosed and its findings are engine code 1361 and engine code 1399 what are this codes and how do I fix them. Just had it tuned new plugs, coils, rotor distributor cap
Friday, February 19th, 2010 AT 9:24 PM
BLUELIGHTNIN6
  • 16,542 POSTS
DTC P1361 : CKP/TDC/CYP Sensor
The CKP/TDC/CYP sensor is built into the distributor and is serviced by replacing the distributor ignition housing.
DTC P1399 : Manufactures Control Ignition System OR Misfire
Replacing distributor ignition housing will also fix the second trouble code as both are related.
Friday, February 19th, 2010 AT 9:44 PM
