2000 Honda Civic Engine Diagnostic Code
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
SHELZ7345
The 'check engine' light came on. I went to a local auto parts store where they offer free engine diagnostics.
The code from the test was 'Misfire Cylinder 2'.
Can you please tell me what this means?
Thanks!
May 26, 2010 at 6:18 AM
OBXAUTOMEDIC
  • 3,717 POSTS
Could be a few things...
Bad Injector or Injector Harness.
Bad Spark Plug. When was last tune up
Bad Spark Plug Wire.
Bad Cap and Rotor
Vacuum Leak
May 26, 2010 at 6:28 AM
SHELZ7345
it's actually time to schedule a tune up.
would this likely eliminate most of the problems/possibilities you've listed?
May 26, 2010 at 7:17 AM
OBXAUTOMEDIC
  • 3,717 POSTS
Sorry for delay in getting back to you...
Yes, it will eliminate all but the Injector and Vacuum.
May 29, 2010 at 9:25 AM
