Thank you. I didn't think of that. but here is another question why would my truck not shift into third or over drive gear? I replaced the shift sensor would the catalytic converter cause that problem too?
Jan 13, 2019 at 4:49 PM
✓Experienced Mechanic
Sorry, I should have explained it better. With a clogged catalytic converter it lowers the vacuum so the computer think the truck is under extreme load which backs the shift points up. Please run down the guide to see if that helps. I would disconnect the exhaust and drive it to see how the power and shift point change.
Jan 14, 2019 at 1:34 AM
TOPHER SAVERANCE
MEMBER
Okay, I'll try it.
Jan 14, 2019 at 2:07 AM
TOPHER SAVERANCE
MEMBER
What if I run it to red line and then it still does not want to shift?
Jan 14, 2019 at 2:28 AM
Did you have the exhaust disconnected? If so lets run the codes to see what come up.
