White smoke coming from under the engine
2010 NISSAN X-TRAIL
13,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
PORTGAS D ACE
  • 28 POSTS
Hello, i have noticed that there is white smoke coming out under the engine. what problem i have?
Mar 4, 2020 at 6:04 AM
SCGRANTURISMO
  • CAR REPAIR CONTRIBUTOR
  • 4,897 POSTS
This sounds like you probably have a coolant leak. The best way to determine where the leak is coming from if you can't locate it by looking under the hood is to do a cooling system pressure test. Here is a link to a guide below explaining how to do that:
https://www.2carpros.com/articles/radiator-pressure-test
Please go through this guide and get back to us with what you find. We can go from there.
Thanks,
Alex
2CarPros
Mar 4, 2020 at 6:16 AM
