Engine cranks no start
150 MILES • 3.8L • 6 CYL • 2WD
BONNEVILLE85
Car trying to turn over but won't start.
Dec 10, 2019 at 11:40 AM
  • 110,248 POSTS
Have you checked for spark and fuel to the engine? The easiest thing to do is see if it starts for a couple seconds using starting fluid. If it does, then we can assume it is a fuel related issue. If it still doesn't start (even for a couple seconds), then we can assume it is ignition related.
Here are a few links you may find helpful:
Dec 10, 2019 at 12:14 PM
