New headlight bulb burnt out when turned on
80,100 MILES • V6 • 2WD • AUTOMATIC
RUNNER50
I have a short, Multi-meter test said Memory fuse 15a and power conn 30a fuse is where the short is at. Both fuses are good. I guess somewhere in these wires there is a short but don't know where to look.
Thanks, Dave
Jan 16, 2020 at 8:23 PM
CARADIODOC
  • 34,414 POSTS
Shorts will make the bulb not turn on. There's only two things that can cause a repeat failure for a halogen bulb. One is if the charging system is over-charging the battery, causing the system voltage to be too high. The more common problem is the glass of the bulb was touched. Fingerprint grease will burn through the glass, leading to the failure.
Please describe the test you preformed or how you did it, and the results. Were you using a voltmeter, ohm meter, or amp meter? What was the indication that you interpreted as a short?
Jan 17, 2020 at 5:44 AM
