Will not start, electrical issues
145,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
JUSTINRAY87
Hello, my vehicle was running great until a few days ago. Went out to start it, put the key in and turned it, got nothing. tried a few times and got nothing. All of a sudden, turned the key, gauges came on but wouldn't crank over. I pulled the battery and had it tested, was told the battery passed fine. put it back in, still no crank. Jumped it and after a few minutes it started, all was fine for a day, battery charged up over 14 while running started up multiple times just fine. next day went to start it and again no power, will only start if I jump it. still seems to charge while driving but as soon as I shut it off, I got nothing. Any advice would help.
Apr 24, 2022 at 10:51 AM
  • 110,244 POSTS
Based on your description, it sounds like you have a faulty connection which is likely at the battery. What you described is usually caused by a loose or corroded terminal.
Take a look through this link and let me know what you find or if you have other questions:
If this is something you have already done, let me know that as well.
Apr 24, 2022 at 1:21 PM
