Electrical interference on ignition system from power lines
105,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
KRILLIN
We have a van that shuts down momentarily when we pass a certain spot near power lines. The engine shuts down for an instant and then starts back up after we drive through the spot. It used to be only at a certain spot but just recently while on trip the same thing happened three times in several different states. Any help would be appreciated. Is there any shielding that I can use to stop this?
Dec 31, 2017 at 5:56 AM
  • 31,937 POSTS
Without knowing exactly what is causing the interference be it electrical or certain frequency radio wave interference, there is very little that can be done. i would contact Toyota direct go above the dealer level and ask if this problem as been reported before and if there is a know fix. some European cars have a problem with the audio system acting up under certain external electrical conditions and odd atmospherics as well, and some improvement has been to fit a anti static strap to the car, but i would contact Toyota and ask there first. within the electrical system of the car is what is known as a CAN BUS which has its own shielding, there may be a problem here. the way it works is somewhat involved to repeat here, but if there is a problem, there can be a U code set in the PCM. U codes are communication codes and this should show if there has been a break in data transfer.
Dec 31, 2017 at 12:36 PM
