2002 Toyota Sienna Van Stalls
109,500 MILES • 6 CYL • FWD • AUTOMATIC
MATTANG
I have a 2002 Toyota Sienna and sometimes when you start it the engine will die. Anytime you let off the gas pedal the engine will die. I can drive it and it works fine if I use both feet one on the brakes and one on the gas to keep it going. Once I get it on the highway and go to a higher speed it seems to correct it self and works fine after that for a week or two and then it does it again. What do you think causes that?
Nov 10, 2008 at 2:10 AM
MELTILLIS
  • 13 POSTS
I own a 2001 Toyota Sienna, it would not stay running when at Idle. Toyota put an line from the exhaust into the throttle body to help return and burn any excess fuel originally not burned the first time thru the system. On my vehicle I have taken the hose off of the throttle body down to where this exhaust line re-enters the throttle body (right at the butter fly valve in the throttle body). I cleaned the carbon that had built up around the butter fly valve (with carburetor spray cleaner) to remove the carbon. Reassembled the disassembled componets. My vehicle then idled properly. Other wise you must keep the vehicle above an idle to keep it running. When you had to stop or slow down and the idle dropped low enough the engine would die. After cleaning it has worked fine. I hope this help other Sienna owners.
Dec 6, 2008 at 4:24 PM
