electrical circuit problem?
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
MING FENG
  • 82 POSTS
Dear all,
My vehicle listed above is giving me trouble again. I went to a store, and everything was fine when I arrived. However, when I left, the transmission gear shift got stuck. I removed the small button cover on top, used my finger to push it, and was able to shift into "D" (the transmission is automatic).
While driving home, I noticed some issues:
The speedometer showed 0, and the mileage meter didn’t move.
The cigar lighter socket had no power, so I couldn’t charge my phone.
The clock display wasn’t showing the time.
Despite these issues, the car drove normally.
I suspect there’s an electrical circuit problem, and it seems like the components above might share the same circuit. I think it’s most likely a blown fuse, but with so many fuses, I’m not sure where to start. Should I check each fuse one by one, or do you have any suggestions?
Thank you for your help!
Ming
Dec 30, 2024 at 5:22 AM
  • 55,616 POSTS
Yep, I would start by checking the "cigar/meter" fuse in the fuse panel by the left side kick panel inside the car.
Here is a guide to help:
Please go over this guide and get back to us.
Dec 31, 2024 at 4:08 AM
MING FENG
  • 82 POSTS
Thank you, Ken. I will try in the next few days and let you know. Happy new year!
Dec 31, 2024 at 10:30 AM
  • 55,616 POSTS
Sounds good, Happy new year! to you as well :)
Jan 1, 2025 at 2:37 AM
MING FENG
  • 82 POSTS
Ken,
It's the cigar 15A fuse. After I replaced it everything is back to normal now.
Thank you so much,
Ming
Jan 9, 2025 at 1:58 PM
  • 55,616 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Jan 10, 2025 at 1:31 AM
