headlights flash
198,000 MILES • 5.9L • V8 • RWD • AUTOMATIC
CURTIS KEATON
My truck runs and drives but the headlights flash. I also have no turn signals or windshield wipers because of it. I have looked at relay fuses because there is a ticking underneath fuse box. I do not know a lot about vehicles but I have tried everything I can think of and then some. Thanks!
Mar 4, 2017 at 10:38 AM
STEVE W.
  • 15,394 POSTS
OK, you have no turn signals, do the Hazard lights work? Do the headlights flash on both high and low beam?
Check fuse 11, fuse 13 in the power center under the hood. If both are OK verify that the ground on the firewall drivers side is good for all the attached wires.
If that checks out OK the most likely item is a failing front control module.
It controls all of those items. It's a part of the integrated power module AKA, smart fuse box. Used/salvage or dealer are pretty much the options.
Mar 4, 2017 at 12:04 PM
  • 55,658 POSTS
Glad you could get it fixed please use 2CarPros.com anytime we are here to help
Nice work Steve!
Best, Ken
Mar 7, 2017 at 5:43 AM
