Right side low beam will not stay on/light
52,000 MILES
RON LUJAN
My rightside low beam went out, took the cover off then the grill and then the headlight assy off.
replaced both lowbeams with better bright white. Turned on lights both worked. Great.
Tried them again a few minutes after getting everything back together, again right side lowbeams did not light and still don't light up? Help
Sep 21, 2013 at 12:42 AM
HMAC300
  • 48,601 POSTS
check to see if the tan/white wire is giving power to headlight. if not it may be a tpim module which is a very expensive thing to replace. of course it may be just the bulb as well.
Sep 21, 2013 at 1:11 AM
