Electrical?
170,000 MILES • 4 CYL • 2WD • MANUAL
CHINDHU SUDHI
When starting my car, a steering wheel sign shows on the dashboard and steering wheel became very hard, then RPMs guage,temparature guage, and A/C stops working. gauges came to zero and A/C stop giving cooling only air coming out from A/C holes. And usually in my car if i am delaying to changing the gear next gear number is showing on the dashboard when this issue occurring the gear changing dash board indication also stop working.
Jan 10, 2023 at 2:56 AM
  • 110,248 POSTS
You mentioned there is a number that shows up if you delay the shift. What is the number?
Also, because this is a newer vehicle, I strongly recommend having the can-bus scanned for diagnostic trouble codes.
CAN stands for controller area network. Basically, the different modules are tied together via a few wires. If there is a code stored, this will retrieve it.
Here is a link that shows how it's done:
Let me know what the number is and if you can have that type of scan done.
joe
Jan 10, 2023 at 11:21 AM
