Electric fuel pump choice
PATENTED_REPAIR_PRO
  • 1,853 POSTS
When I asked you if the engine runs better when loosening the gas cap, I don't see where you answered that?
Friday, January 25th, 2019 AT 3:48 AM
DANIYALKZA
  • 111 POSTS
No it doesn't change at all. I have a question is a electric fuel pump flow and pressure change with engine rpm? Or it has a stable flow and pressure no matter low or high rpm?
Friday, January 25th, 2019 AT 4:36 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
The fuel pressure is determined by the fuel pressure regulator. If the regulator is on the engine at a fuel rail, etc and has a vacuum hose to it, changes in intake manifold vacuum from changes in engine rpm will cause a slight change in pressure but I believe the flow will remain the same.
Saturday, January 26th, 2019 AT 12:21 PM
