I made a mistake which caused the massive knock.
I now still have a knock and it is not all the time, but biggest problem now is when truck is in park or gear when stopped and engine is warm the rpm will fluctuate from 500-800 then smooth out back and forth. When engine rpm goes down to 500 the knock is worse then the knock gets a lot quieter when rpm evens out. Do you think a bad EGR valve or a messed up gasket could cause this? The truck also has a vibration when in park or gear still.
Monday, April 23rd, 2018 AT 3:04 PM
