Engine power reduced/engine disabled
117 MILES • 2.0L • 4 CYL • 2WD • MANUAL
SGONZALES76
When trying to turn on the car it will turn on and turn off. shortly after a light comes on and says engine power reduced engine disabled. How do I get rid of that or what do I need? Have already tried to change the battery and that does not help.
Dec 1, 2017 at 5:04 AM
STEVE W.
  • 15,411 POSTS
There are several things that can cause that light to come on, from a failing throttle position sensor to a transmission fault. The first step would be to get a scan tool and pull the codes that will be in the computer. Those will give a direction as to where to test next. Just keep in mind that the codes very seldom mean "change part A" instead they will point out what the computer is having a problem with. Could it be a bad part? Yes. But it could also mean that the plug connecting the part to the harness is corroded or the wiring has a problem. Once you have the codes many parts stores will do a free scan, and then proceed to tell you "part A is the problem", just write down Eevery code and post it here. That will give a starting point.
Dec 1, 2017 at 10:05 AM
