ECM programming?
250,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
DLEON
Replace ECM with a used one how do I reprogram?
Sep 22, 2018 at 11:56 AM
STEVE W.
  • 15,377 POSTS
You need to have a pass through device and a connection to the correct Honda factory software to do the programming. Using either the factory Honda scan tool or an aftermarket unit will work. You will also need to reprogram in the immobilizer information. If you do not have those tools it will be cheaper to have a shop or dealer do it as the tools and software are very expensive.
Sep 24, 2018 at 6:08 AM
