Stalling and hard to start
145,000 MILES • 4.1L • 6 CYL • 4WD • AUTOMATIC
  • 15 POSTS
Replacing ECM, do I have to relearn the crankshaft position sensor? I was all ready to replace the ECM when I came across this information. I only have a actron 9600 tool, I do not think I can relearn the cps with it. My ECM has already been flash program.
May 14, 2016 at 1:07 AM
SATURNTECH9
  • 30,869 POSTS
Yes you would have to relearn the crankshaft position sensor.Your actron cannot do that. It takes a advanced scan tool to it.
This guide will help
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
May 14, 2016 at 5:36 AM
  • 15 POSTS
Thanks. I got the ECM installed, but I still have the same problems. I spent $2000.00. I have gone through three techs, still no fix. Kind of at the end of my rope. Thanks for listening.
May 15, 2016 at 7:12 AM
SATURNTECH9
  • 30,869 POSTS
So what is the problem your having? Please share.
May 15, 2016 at 7:15 AM
  • 15 POSTS
Stalling and hard to start. I have had fuel pump, relays fuses, plugs ,throttle body and ECM replaced. Also has p0410 code. Maybe oxygen sensor?
May 15, 2016 at 7:20 AM
  • 15 POSTS
I also had the rim replaced. It is stalling and hard to start. On the interstate 60 mph it may just die, like I it is not getting fuel. Then will not start. I pulled a fuse or relay, plugged it back in. Bang, it starts and I can drive it for a while.
May 15, 2016 at 7:41 AM
SATURNTECH9
  • 30,869 POSTS
So when it stalls and dies what are we loosing spark or fuel pressure? Also have you thought about a bad fuse box or loose connection to the fuse box?
May 15, 2016 at 7:44 AM
  • 15 POSTS
I think its fuel pressure. Whenever I pull fuel pump relay or fuse and plug it back in, it usually starts.
May 15, 2016 at 7:50 AM
SATURNTECH9
  • 30,869 POSTS
That does not really make sense unless your pushing on the fuse box causing it to start.
May 15, 2016 at 7:53 AM
  • 15 POSTS
It does not make sense, yet it has been a seeming quick fix when I am stuck along the road. Sometimes I unplug the battery and it seems to do better. Maybe that one has nothing to do with the other, but when I am stuck out on the road with my wife I have to do something. These things seem to help. I like your thinking on the fuse box. It is something to look at.
May 15, 2016 at 8:04 AM
SATURNTECH9
  • 30,869 POSTS
I have seen open terminals going to the fuse box plus bad fuse boxes causing issues like that.
May 15, 2016 at 8:08 AM
  • 15 POSTS
Thank you! I will look into these things and get back to you. Talking with you has calmed me some. Thank you again. Larry
May 15, 2016 at 8:15 AM
SATURNTECH9
  • 30,869 POSTS
You are welcome try just pushing on the fuse box while someone tries starting it. Also I would unplug all the connectors to the fuse box and look at the connectors looking for open terminals.If you compare them to the other connectors they really stand out.
May 16, 2016 at 2:39 AM
  • 15 POSTS
Thanks, I will try that. I am at work, so I will do it later this afternoon. Assuming it starts and I get home. Haha!
May 16, 2016 at 2:48 AM
RENEE L
  • 1,260 POSTS
Great job SATURNTECH9! We really appreciate your expertise and staying with Larry helping him get to the bottom of his car issue. Hopefully he will get back to you with his findings.
May 16, 2016 at 4:50 AM
  • 15 POSTS
Yes, Saturn has been great. The car was running and I pressed around on the fuse board. It died when I pressed on the fuel pump relay. I don't know if that's a problem or if it died because it does sometimes. Can the fuse board be taken off easily? What do you think?
May 16, 2016 at 6:20 AM
SATURNTECH9
  • 30,869 POSTS
Let's try to make it die one more time just to be sure? But it sounds like we're down to the things bad relay bad fuse box or open terminals on the wires to the fuse box.
May 16, 2016 at 7:53 AM
  • 15 POSTS
Well, new stuff. It doesn't, as of now, have a hard time starting nor does it die. I was driving it lurched and runs like a loose plug wires. Slight smell of sulphur. But it seems to start and not die.
May 17, 2016 at 3:47 AM
  • 15 POSTS
Code p0304. Cylinder4 misfire
May 17, 2016 at 4:01 AM
SATURNTECH9
  • 30,869 POSTS
So is the misfire intermittent?happen all the time? Also is it worse with the AC on if your AC works?
May 17, 2016 at 5:28 AM
  • 15 POSTS
Misfire all the time. How can it be that it starts all the time now, also it doesn't stall? This problem and the other we were working on related?
May 17, 2016 at 5:35 AM
SATURNTECH9
  • 30,869 POSTS
So at idle the miss fire is constant like one cylinder is firing at all?Also any codes to tell us which cylinder is missing?
May 21, 2016 at 5:04 AM
  • 15 POSTS
It had a po304. I put coil cyl 4 on cylinder3, and vice versa. I found I had a po300 after. I figured 4 coil was bad, after changing the coil I had a smooth running auto. Thanks for your time.
May 21, 2016 at 9:31 AM
SATURNTECH9
  • 30,869 POSTS
That's great glad to hear you got it fixed those coils go bad all the time.
May 21, 2016 at 9:55 AM
TRAILBLAZER KEVIN
2003 Trailblazer, 6cyl, My won't start when the temperature outside gets below 30-35 degrees. When the temperature is warmer is starts right away. Check engine light comes on when it does start and after the second or third start goes off. Have taken to local shop and they say the codes are not common and seem to think it is in the wiring. The temperature has been under 30 degrees for a week now and will not start now. What is wrong?
Dec 17, 2019 at 10:58 AM (Merged)
  • 110,248 POSTS
Check to see if you are getting spark and fuel to the engine. If it won't start, one will be missing. Refer to our homepage under the DIY section for direction for checking both. Once you determine which is missing, then you know what circuit or system to attack.
FALEULU11
hey i have a 2002 chevytrailblazer ltz with 140,000 miles on it mine car engine started shaking an its little hard to go up hills i dont know if its the engine? or something eles?"
CARADIODOC
  • 34,414 POSTS
Yes, it's the engine. What you described is typical of a misfire. How long has it been since the spark plugs were replaced? Have you checked for diagnostic fault codes? Many auto parts stores will do that for you for free. Has the Check Engine light turned on? If it has, most likely there will be a fault code indicating which cylinder is misfiring. If new spark plugs don't solve the problem, you might also suspect one of the ignition coils. You can verify that by swapping the one from the misfiring cylinder with one of the other ones, then erase the fault codes and see if a misfire code sets for the same or different cylinder.
