1995 Eagle Talon Engine bogs.
CHESTER22
Engine Mechanical problem
1995 Eagle Talon 4 cyl Front Wheel Drive Manual
Hello, my name is marc and i have an eagle talon tsi with a 4g63t in it and i have a question. The car will start up fine and will run fine, but after a minute or so it would bog down and lose power even while sitting in the garage and yuo rev it from the engine it wont accelerate. i checked the timing, replaced the spark plugs and gapped them right, checked the o2 sensor and is good, changed the fuel pump, did a fuel pressure test and it was good. The only other 3 things i could imagine it being is either the fuel pressure regulator, throttle position sensor or a maf sensor but i want a mechanics opinion on what the major thing is wrong with it or if i am missing anything.
Aug 19, 2009 at 10:16 AM
CH112063
  • 1,320 POSTS
The big things that I found wrong with that engine was timing belt problems, upstream and downstream O2 sensors and once, a catalytic converter. Moniter it with a scan tool and use that tool to reset the MIL lamp also. It may have been fixed already but it was nec. to use electronics to relearn the PCM after a disasterous emmissions failure. The country was very prone to the newer legislation at the time of software developement for fuel and spark management and those took a back seat to possible emmissions problems. And it made sense at the time, but they have since gotton a little more common sense to fixing this stuff. I did mostly transmissions at that time on them.
Aug 29, 2009 at 8:04 AM
