1989 Eagle Summit Acceleration issue
74,150 MILES • 4 CYL • FWD • AUTOMATIC
RYAN BAILEY
Just to set the stage the car was my grandmothers and it became mine. It took me a while to get my liscence and my car was fine when i got it. It sat for 2 years not driven. I had the exshaust system replaced entirely and new spark plugs installed. I had the car towed to the garage since it didn't start up to be driven there. Its after the garage that the problem was recognized.
This is the problem in the best way i can describe it. When i push in the gas i do so like you would on any car and it starts out fine. I get up to 20-25 MPh and it stops accelerating so i push the gas in almost petal-to-the-metal and it kicks back and jolts foward accelerating. I havent gone to my mechanic yet but i have been perplexed to what could be causing the situation. I have run that gas tank cleaner through it in case that was the problem but there was no change. its a great car and has lower miles than alot of people that own one, and my grandmother kept great care of it. Im wondering if it could be a clog in the gas filter but i don't want to do something that could make the problem worst. What do you think it is? and is if the problem is the gas filter is it a do it yourself project. Im 21 and don't know a whole lot about cars.
Apr 27, 2008 at 6:26 PM
  • 75,988 POSTS
The problem you have lies on the hand of an ASE technician its not a DIY its beyond you-Sorry
If I was you I'll replace the fuel filter and then turn around and check the actual fuel pressure. Fuel system okay-next step for a start is to inspect and test the airflow sensor/throttle position sensor/
Apr 27, 2008 at 6:40 PM
