1995 Eagle Summit 95 Eagle summit will not turn over
250,000 MILES • 4 CYL • FWD • AUTOMATIC
SUMMITROCKET
I have and 95 eagle summit with a 2.4 4bangger that will not turn over It start when i left my lights on in my car at school and came back and my battery was dead so a buddy gave me a jump and it was having a hard time starting so i gave it some gas and it started got home and it was running really quite when i came in my drive way then stald and i turned the key i wouldent even crank i just hear a my solinoid clicking and fule pump working
Apr 16, 2010 at 9:32 AM
CH112063
  • 1,320 POSTS
After awhile if you leave the battery drain it does something called deep cycling and is internally shorted. You could try getting a battery charger and slow charging it over 24 hours, if it still won't work replace it. Use a 5 amp hour setting. And Good luck. The car will not charge, or run correctly until you install a good battery.
Apr 17, 2010 at 1:42 PM
SUMMITROCKET
i did i voltage test on my battery it came out about 10 volts so the battery is fine so my buddy in auto shot told me to test my starter with a battery and jumper cables and after hitting it a few times it made a noise so i bought a new starter and walla she runs Vroooooooomboomboombombem!!!!!!! errrrrrrrrrrrrrrt!!!!!!!!
May 2, 2010 at 11:33 AM
