1985 AMC Eagle Limited Rich Smoke Stall
Suggested Repair
Black smoke indicates a rich air/fuel mixture. Confirm the choke opens fully after warm-up. Test the choke pull-off by disconnecting its vacuum line, depressing the rod, and covering the port; the rod should stay depressed, otherwise the pull-off is faulty. Also check that the idle screw is not holding the throttle shaft open too far, which can draw excess fuel through the carburetor and cause dripping at idle.
Conversation Summary
The owner of a 1985 AMC Eagle Limited says the engine runs after a cold warm-up but sometimes stalls while driving and will not restart for about 30 minutes. Restarting requires holding the throttle until idle stabilizes. Thick black exhaust smoke smells of fuel, collected drips burn, and fuel economy is about 6 mpg. Vacuum lines were recently replaced and an emissions test was passed with technician help. Advice is that the mixture is too rich: verify full choke opening when warm, test the choke pull-off, and check that an overly high idle-screw setting is not holding the throttle open and pulling excess fuel through the carburetor.
