When it gets cold my truck stalls
200,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
CKANE8651
when it gets cold my truck dies, I have a new alternator and battery. this past time it died once I got it started again I had a major power loss and the exhaust was way louder. the coputer said I needed new spark plugs and ignition coil which would explain some of the power loss but not as much as I did loose. it also doesn't explain why it keeps dying randomly.
Jan 3, 2016 at 4:06 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner then check fuel pressure with a guage. auto parts rent it.
Jan 3, 2016 at 11:57 PM
CKANE8651
Thanks I'll let you know if it works
Jan 4, 2016 at 5:56 AM
CKANE8651
I replaced 2 coil packs and cleaned the while throttle body, the truck is running like new
Jan 9, 2016 at 1:30 AM
