Does the driveshaft have to be installed the same way?
220,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
GERRETTF22
Does my front and rear driveshaft have to be installed the same way I took them out? Or does it not matter?
Apr 2, 2024 at 1:18 AM
  • 55,658 POSTS
They say you are supposed to make the driveshaft when removing it, but I have never had a problem with it because the unit is balanced independently. Here is a guide to help:
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
Let us know if you need anything else.
Apr 2, 2024 at 1:47 AM
