drivers side window will not go up
170,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
All windows working except the drivers side window. Went down fine but will not go back up. No sounds when using the switch.
Sep 16, 2019 at 12:29 PM
  • 110,248 POSTS
Welcome to 2CarPros.
As far as the window motor, the direction is turns is based on polarity (which wire gets power on the motor). If it works in one direction, usually it will work going the other way. Not always, but more often than not, it is a bad connection at the motor or the switch has failed.
If it has already been fixed, let me know. If it hasn't, there are two wires on the window motor. One gets power when up is selected, and the other gets power when down is selected. Confirm if you have power to both.
Here are a few links you may find helpful:
Let me know what you find.
Sep 16, 2019 at 12:39 PM
