Driver side tail light does not work
90,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
CORY HALL
My grandmother has the car listed above and the driver side tail lights do not work. I think this is due to corrosion but none of the lights work on that side. It is not one piece for all the bulbs like the Grand Am. So I was wondering if anyone had any suggestions on a fix? Thank you.
Feb 12, 2017 at 2:49 AM
JIS001
  • 3,412 POSTS
If there is water intrusion in the housing, then pull the light assembly out and inspect all bulbs and connectors. They do sell a repair kit for the connectors at your local parts store. They may need to special order it.
Good luck and let us know what you find.
Feb 12, 2017 at 5:36 AM
