Turn signal and rear parking lights do not work. We have replaced bulbs and control in steering column.
Wednesday, August 17th, 2016 AT 4:49 PM
HMAC300
MECHANIC
Check for a bad flasher for turn signals and ground for taillights which is lower front of engine or broken wire going to ground for taillights. It can also be a multi function switch that is bad. Turn signal relay is below dash right of steering column.
