Driver power window wont go down
98,000 MILES
DARRELL07
the Driver power window won't go down. passenger side switch works fine. no noise. i tried to find the fuse for that function. how do you take off the door panel? also the key less entry doesn't work for the passenger side rear sliding door lock?
Sep 14, 2013 at 1:56 AM
TY ANDERSON
  • 719 POSTS
Does any of the switches on the driver side door work? There is only one fuse covering all the windows so I don't think it that because the passenger side is working. Its a 40A fuse in the under hood fuse box or what is called the totally integrated power module.
The driver door panel is secured with screws and plastic clips. Remove all screw (3-4) look all around the door panel for screws and then you need to carefully pry on the door panel away from the door. When each clip comes out it will pop off so start at the bottom of the door panel and work you way from right to left until each clip has popped off. Then lift the panel up and disconnect the electrical and cable attached to the interior door lever.
The power sliding door on the passenger side does nothing when pressing the remote to open the door right? Or does the door open then stop? Talk to you soon, TY
Sep 14, 2013 at 2:19 AM
