Unable to unlock door with key fob or the key. Key will not even turn once in lock.
Sep 10, 2018 at 3:38 AM
AL514
✓Experienced Mechanic
Hello, thanks for using 2CarPros.com. It sounds like the key cylinder, where you actually insert the key may be bad. Does the key work okay for all the other doors? The cylinder is replaced from the inside of the door panel. They are relatively easy to take apart. Here is an article on removing the panel from the door. You can see everything pretty easy once the panel is removed. https://www.2carpros.com/articles/door-panel-removal
