Does not stay started every now and then
250,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
AMONT1986
Every once in a while my vehicle doesn’t want to start. If I push the gas in and start it it will start but I have to rev engine to at least 1500 rpm's for in between 30 seconds to a few mins. If I don’t do that it just dies. After that it runs and drives fine. Any idea what it could be before I just start replacing things?
Sep 19, 2019 at 5:20 AM
CARADIODOC
  • 34,414 POSTS
A real common cause of this is disconnecting the battery or running it dead. The Engine Computer looses everything in memory. Most of that will be relearned on its own except for "minimum throttle", which takes a very specific set of conditions to relearn. To meet those conditions, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals. Until that is done, the computer won't know when it must be in control of idle speed.
If that doesn't solve the problem, you'll need a scanner so you can watch the "idle steps" the computer has placed the idle speed motor to. It can place it at one of 256 positions. As its armature slowly rotates, a threaded shaft retracts or extends a pintle valve that opens an air passage around the throttle blade. Also, as it increases the number of steps, it increases the number of milliseconds it holds the injectors open, to increase fuel. Those two things control idle speed.
Typical for a properly-running engine is to find the idle steps around 32. With one misfiring cylinder, expect to see it at around step 50. If you find it at "0", minimum throttle hasn't been relearned yet.
The next thing is to watch what happens to those idle steps when the stalling or low idle speed occurs. For example, if idle speed is too low and you see the steps going real high, the computer is trying to raise idle speed, but without success. If idle speed is too low and the step number is real low, (but not "0"), you have to look for why the computer is requesting such a low speed. Usually that's due to an inaccurate reading from a temperature sensor.
Sep 19, 2019 at 9:10 AM
