Does not start but turns over
2007 NISSAN MURANO
140,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
DMACIAS2018
Car began having issue a few days earlier. it was stumbling at idle. Now it will not start. There are no codes present. There is fuel.
Apr 24, 2018 at 1:58 AM
HARRY P
  • 2,292 POSTS
Have you checked for sparks? I would say get a spark tester and check all of your cylinders for sparks. Here is the tester that I use: https://www.amazon.com/Lisle-20610-Inline-Spark-Tester/dp/B0002STSC6/ref=sr_1_3?ie=UTF8&qid=1501325755&sr=8-3&keywords=spark+tester
You can get it at the local parts stores as well, but it will cost you a few bucks more.
Also, quite simply, have you checked the fuses? A blown fuse can wreak all kinds of weird havoc.
Apr 24, 2018 at 3:36 AM
DMACIAS2018
All coil packs have been replaced. Do you suspect signal issues? I did check fuses. I will see about checking spark.
Apr 24, 2018 at 3:58 AM
HARRY P
  • 2,292 POSTS
Well you said that there is fuel. So I am just trying to narrow things down a bit. At 140,000 miles, there are a lot of possibilities. You could be getting fuel, but not enough fuel. So we check sparks and see. Another way to check is to spray some starting fluid into the air intake tube and then try to start it. If it fires and almost starts or does start, then the problem is fuel delivery. If it does not make a difference, then the problem has something to do with sparks.
Apr 24, 2018 at 4:02 AM
DMACIAS2018
Thanks, I will try to make it start with starting fuel.
Apr 24, 2018 at 5:29 AM
