Does a 4WD suburban come with a posi rearend by default or was it an option?
104,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
PACEVETTE
Thanks, Mike.
Oct 31, 2022 at 7:41 AM
  • 55,464 POSTS
This was an option, some came with a traditional split power rear end. You can tell if your is a positraction if you pull the rear cover and if it has a small spinner like this differential was you have a positraction unit.
https://youtu.be/ytqXLSjHNm0?t=309
Use 2CarPros anytime, we are here to help. Please tell a friend.
Nov 1, 2022 at 2:36 AM
