1993 Chevy Suburban
KASSIDYABBYGALE
  • 1993 CHEVROLET SUBURBAN
1993 Chevy Suburban V8 Four Wheel Drive Automatic
Im trying to fix my 1993 suburban which has the rear end locked up, was wondering if u could help? If I could have a manual just on how to fix the rear end that would help alot thank u
Saturday, September 25th, 2010 AT 1:47 PM
HMAC300
  • 48,601 POSTS
There are 3 different rear axles for your truck and you need to know which one you have. You can go on the site here and get an online manual for $10 and print what area you need to help with your problem. BUt you need a dial indicator to set backlash and pinnion depth. And an inch pound torque wrench to set pinion bearing drag or know what you are doing otherwise you'll burn the bearings out on the pinion.
Thursday, September 30th, 2010 AT 9:02 AM
