1998 Dodge Van HELP Dodge Ram van won't start after flat ba
BRIT_LAD
  • 1998 DODGE VAN
1998 Dodge Van
The same question as before but with new heading.
I had a flat battery on my ram van 1500, tried jumping it with no real luck then I charged it and still would not run, it cranks for 10 seconds then starts to die then I try again and same thing. The weird thing to me is that if I give it gas when cranking it will run until I lift of then dies. When it does run run like this it runs like crap, not clunky, but does smoke a little and just isn't right.
Tuesday, October 28th, 2008 AT 8:54 PM
BMRFIXIT
  • 19,053 POSTS
Check for codes and check for vacuum leaks
is it due for tune up know is the time to do it and or check it
check charging system and alternator
cycle key ON OFF ON OFF ON and get the codes P****
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Saturday, November 1st, 2008 AT 10:51 PM
