speed sensor
EDELRIO
My speed sensor went out on my 93 dodge van, I replaced it with the aftermarket sensor at the local parts store, after installing and reconecting to socket I still have check engine light and no speedometer. Do I need to have the light removed by a obd 1 for it to recognize the new sensor?
Jul 26, 2007 at 9:53 AM
RACER93
I have a 1999 dodge truck 1500 4 wheel drive,has 360 motor and 125,000 miles on it. Check engine light came on my scanner , came up with code 720, output speed sensor ciruit malfunction. What is that and how do I fix it.
Sep 13, 2007 at 11:09 AM
CSLABACH
98 Ram 1500 5.9 Auto, check engine light, ABS, brake warning lights are on AND no speedometer or Odometer. Therefore, no crusie either.
Did a brake job...no change, replaced a solonoid on the top side of transmission, could be removed from under the truck without openning the transmission...no effect.
What else?
Sep 14, 2007 at 8:18 AM
  • 75,988 POSTS
[quote:8dab813ac5="cslabach"]98 Ram 1500 5.9 Auto, check engine light, ABS, brake warning lights are on AND no speedometer or Odometer. Therefore, no crusie either.
What else?[/quote:8dab813ac5]
Welcome to 2carpros
This is a complicated problem-to begin you need to have the OBD2 system scanned for code/s and comeback with it.
Sep 14, 2007 at 1:51 PM
2CARPRO JACK
  • 11,533 POSTS
According to Mitchell that code pertains to the cruise control system.It could be several different things. I would go to link at bottom of main forum page to Mitchell-On-Demand and look it up..It is in "Accessories and Equipment" there you will be able to follow the troubleshooting charts and figure this out
Sep 15, 2007 at 1:21 AM
