Wednesday, October 16th, 2013 AT 11:13 AM
It ran great then changed front brake lines now having trouble. Couldn't find any vacuum leaks, took it autozone they put the scanner on it and came up with two oxy sensor codes PO132 and PO138. I was told the odds of both of them going bad at the same time is rare especially after the repair. How can I tell if they are really bad and what else can cause these codes? The engine idles fine starts fine but when it gets warm and up around 50mph it sputters falters and loses power but it doesnt stall.
