2001 Dodge Truck O2 Sensors
PD1096
I'm tuning up my girlfriends 2001 1/2 ton Dodge pickup. The truck has the 318 engine with around 135,000 miles on it. I crawled under the truck to replace the O2 sensor and found what I believe to be two of them. Are there two O2 sensors on this truck ? I hope not ... they're expensive !
Aug 18, 2007 at 1:23 PM
SERVICE WRITER
  • 9,123 POSTS
Good news and bad news. Be glad there are only two and not four. The front one anyalzes the gases going into the converter and the rear one analyzes that geses coming out of the converter to make sure its doing it's job. Unless they are faulty, don't touch them. Use the money saved to take your sweetheart out to dinner. Since your doing the tune up, don't forget to do some carbon cleaning. The throttle plates and intake valves should get hit. Here is one such product that I like, but there are others:
https://images.2carpros.com/forum/automotive_pictures/30961_seafoam_1.jpg
http://www.seafoamsales.com/motorTuneUpTechGas.htm https://www.2carpros.com/how_to/how_to_tune_up.htm
Aug 19, 2007 at 1:07 AM
Suggested Repair
This truck has two oxygen sensors: one before the catalytic converter and one after it. Do not replace them unless they are faulty. During the tune-up, clean carbon from the throttle plates and intake valves with a product such as Seafoam.
Conversation Summary
The owner of a 2001 Dodge half-ton pickup with a 318 engine asked whether the truck has two oxygen sensors after finding two while preparing a tune-up. The expert confirmed there are two rather than four: the front sensor checks gases entering the converter, and the rear sensor checks gases leaving it. The expert advised leaving both sensors alone unless they are faulty and recommended carbon cleaning of the throttle plates and intake valves as part of the tune-up.
