dodge 1500
IRON MAIDEN
I have a Dodge 1500 2000 with 113000 miles with a 5.9 360 engine. engine light is on and speedometor does not engage til I reach about 55 mph. We changed the speed sensor located at the tranny but is still not working. whats up
Oct 30, 2007 at 8:07 PM
SERVICE WRITER
  • 9,123 POSTS
Run to the hills.....Run for your life.....
I haven't looked to see what set up this one has ( so forgive me if I'm wrong), but if you take out the speedo cable and rotate it manually, does it affect the speedo?
Oct 31, 2007 at 1:18 AM
SYNCRAIT
  • 235 POSTS
on top of the rear differential there is another speed sensor that is causing your problem replace it and everything should work fine. Its not a big job....Good Luck!
Nov 23, 2007 at 4:40 AM
